Vaaman
Axon
SOC
RockChip RK3588S
CPU
8-core 64-bit (4×Cortex-A76+4×Cortex-A55)
8nm lithography process
frequency up to 2.4GHz
GPU
ARM Mali-G610 MP4 quad-core GPU
Support OpenGL ES3.2/ OpenCL 2.2 / Vulkan1.1
450 GFLOPS
NPU
NPU computing power up to 6 TOPS
Support INT4/INT8/INT16 mixed operation
Support framework switching of TensorFlow / MXNet / PyTorch / Caffe
ISP
Integrated 48MP ISP with HDR&3DNR
VPU
Video decoding:
8K@60fps H.265/VP9/AVS2
8K@30fps H.264 AVC/MVC
4K@60fps AV1
1080P@60fps MPEG-2/-1/VC-1/VP8
Video encoding:
8K@30fps encoding
support H.265 / H.264
*Achieve up to 32-channel 1080P@30fps decoding
16-channel 1080P@30fps encoding
RAM
4GB/8GB/16GB
64bit
LPDDR4x
LPDDR5 (Up to 32GB optional)
Storage
4GB/8GB/16GB
64bit
16GB/32GB/64GB/128GB eMMC
Storage Expansion
1 x M.2 interface
can be expanded with 2242 SATA3.0 SSD (default)
compatible with 2242 PCIe2.0 NVMe SSD
1 × TF Card
Wireless
Support 2.4GHz
5GHz dual-band WiFi
802.11 a/b/g/n/ac protocol
Support Bluetooth 4.2 (BLE)
Display
1 × HDMI2.1(8K@60fps or 4K@120fps)
2 × MIPI-DSI(4K@60fps)
1 × DP1.4(8K@30fps)
*Achieve up to four-screen output with different displays
Ethernet
1 × 1000Mbps Ethernet (RJ45)
Camera
2 × 2 lane MIPI-CSI input or 1×4 lane MIPI-CSI
Audio
Audio output:
1 × 3.5mm audio jack
1 × HDMI2.1 audio output
1 × DP1.4 audio output
Audio input:
1 × Mic input(2P-1.25mm)
PCIE
1 × M.2 (PCIe2.0)
can expand with 2242 PCIe2.0 NVMe SSD
USB
1 × USB3.0 (Limit 1A)
3 × USB2.0 (Limit 500mA) (2 of them are connected to 20 pin header)
1 × USB-C multi-function interface (USB3.0 OTG / DP1.4) (Limit 2A)
SOC
RockChip RK3588S
CPU
GPU
450 GFLOPS
NPU
ISP
VPU
Video decoding:
4K@60fps AV1
Video encoding:
8K@30fps encoding
RAM
4GB/8GB/16GB
64bit
LPDDR4x
Storage
4GB/8GB/16GB
64bit
Storage Expansion
1 x M.2 interface
1 × TF Card
Wireless
Support 2.4GHz
5GHz dual-band WiFi
Display
1 × DP1.4(8K@30fps)
Ethernet
Camera
Audio
Audio output:
Audio input:
PCIE
1 × M.2 (PCIe2.0)
USB
Dimensions & Weight
85 x 85 mm
Final weight and height TBD
SOC
Rockchip RK3399 (Dual Cortex-A72 + Quad Cortex-A53)
Mali-T864 GPU, OpenGL ES1.1/2.0/3.0/3.1, OpenCL, DX11
2 GB or 4 GB of LPDDR4 RAM
Power
18-W USB Type-C PD
Storage
64-GB eMMC built-in
PCIe
PCIe 2.1 (4 full-duplex lanes at 20 Gbps)
Real-Time Clock
RTC support via built-in battery interface
FPGA
Efinix Trion T120
Logic Elements: 112,128
Embedded Memory: 5,407 Kb
Embedded Memory Blocks (5 Kb each): 1,056
Embedded Multipliers: 320 (18x18 bit)
512 MB or 1 GB of DDR3L dedicated RAM, x32 PHY with memory controller hard IP, 25.6 Gbps aggregate bandwidth
Supports 1.8, 2.5, and 3.3-V single-ended I/O standards and interfaces
Up to 16 PLL-generated global clock signals
FPGA Interface Blocks
GPIO
PLL
LVDS 800 Mbps per lane with up to 20 TX pairs and 20 RX pairs
MIPI DPHY with CSI-2 controller hard IP, 1.5 Gbps per lane
Direct CSI-2 connectors
Ports
2x USB 2.0 Type-A
1x USB 3.0 Type-A
1x HDMI 2.0 (Micro), Supports maximum 4K @ 60 Hz display
1x MIPI-DSI, Supports 2560x1600 @ 60 fps output with dual channel
1x USB Type-C DP, Supports maximum 4K @ 60 Hz display
1x MIPI-CSI, 2 lanes via FPC connector, support up to 800 MB/s bandwidth
3.5 mm jack with mic
Gigabit ethernet (Realtek RTL8211E)
MicroSD
I/O
40-pin GPIO header: supports one 12-pin PMOD and two LVDS lanes or 25 GPIOs
1x UART
2x SPI bus
2x I²C bus
1x PCM/I²S
1x SPDIF
1x PWM
1x ADC
6x GPIO
2x 5-V DC
2x 3.3-V power pin
