Edge Intelligence — Redefined
AXON-MINI
Compact intelligence for the next generation of edge devices.
AXON-MINI
Powerful Qualcomm QCS6490 Processor Inside
12 TOPS AI NPU Processor for Running Local AI Models
The End of Fixed Ports
Axon-Mini lets you build your own set of connectivity. Swap I/O modules to get the exact set of ports your product needs whether its USB, Ethernet, Storage or more. Stop adapting your products to your existing boards. Instead, let Axon-Mini adapt to your product. Just swap modules and create the communication setup for your application.
Axon-Mini Inside Drones
Real-time intelligence — On the aircraft
Stop relying on cloud latency for mission-critical decisions. Axon-Mini brings onboard compute that enables fast perception, stable control loops, and smarter autonomy, while letting you configure the ports and interfaces your drone actually needs through swappable modules. Get real-time onboard inference (12 TOPS AI) for autonomy, tracking, and inspection without sacrificing flight time.
Most advanced edge AI hardware for Robotics
Deploy Axon-Mini in robots that need dependable local decision-making AMRs in warehouses, inspection robots on sites, and automation cells on factory floors. It supports real-time actions, continuous operation, and consistent performance even when network connectivity is limited with full-featured ROS2 support.
Low-Power AI at the Edge
By processing data locally, Axon-Mini reduces latency, improves reliability, and extends battery life, enabling efficient edge intelligence across a wide range of autonomous machines.
Key AXON-Mini Features
Designed for modern systems, the chipset delivers high-speed connectivity, flexible expansion, and efficient power management—providing a solid foundation for reliable and scalable designs.
USB Type-C 3.1
5Gbps speed + DisplayPort
Upgradable UFS 3.1 Storage
Video Decode Support Up to 4K/60
Virtual Antenna Inbuilt
Swappable Module Connection
Battery Charging Support
Power Over Ethernet Support
BT 5.3 Support
WiFi 6E Up to 1200 Mbps
32/64/128GB EMMC 5.1 Storage
Qualcomm ® Kryo™ 670, Qualcomm® Kryo™ CPU, 8 Core, 64-bit Architecture
• Kryo Gold Prime
One high-performance core at 2.7 GHz
• Kryo Gold Three high-performance cores at 2.4 GHz
Kryo Silver Four low-power cores at 1.9 GHz
Built for Real-World Applications
Features MIPI camera interfaces, FPC display support, and Pogo Pads for debugging, enabling flexible connectivity, fast development, and efficient testing from early prototyping to production.
Edge AI and Machine Learning
With its 12(int8) TOPS NPU and support for various deep learning frameworks, it's suitable for AI applications like image recognition, natural language processing, and predictive analytics.
Embedded Systems
Its small form factor and powerful specs make it ideal for various embedded system applications.
Media Center / Home Theater PC
8K video decoding and encoding capabilities make it perfect for high-quality media playback and streaming.
Video Decode: 1x 4K60, 2x 4K30, 4x 1080p60
Formats: H.264, H.265, VP9
Video Encode:  1x 4K30, 4x 1080p30
Embedded Systems
Digital Signage
The Dual display interfaces (HDMI and Type-C PD or DSI) make it ideal for controlling multiple screens in retail, advertising, or information display settings.
Robotics
Axon-Mini is a full-fledged robotics computer with full ROS 2 support and on-device AI for real-world Physical AI products. Whether you’re building an underwater robot, a flying robot, an industrial machine, or a healthcare robot, Axon-Mini delivers a complete hardware + software solution, built to deploy, scale, and evolve with your robot.
Digital Signage
Robotics
IoT Gateway
With strong network capabilities (WiFi 6, Bluetooth 5.2, Gigabit Ethernet), it can serve as a powerful IoT hub or gateway.
Mini Server
Large RAM capacity and NVMe SSD support allow it to function as a small, energy-efficient server for various applications.
IoT Gateway
Mini Server
Computer Vision Applications
Axon-Mini is built for advanced vision, it has triple 14-bit ISPs plus two lite ISPs , enabling multi-camera capture and processing, supporting up to 3× 22 MP cameras and 1× 64 MP at 30 fps (sensor/interface dependent).
Development and Prototyping
Its maker-friendly design with Pogo Pads, FPC headers, and MIPI interfaces make it suitable for hardware prototyping and software development.
Axon-mini isn’t just an SBC, it’s a full Linux computer in a tiny, powerful form factor, capable of running 70,000+ Linux software packages (Debian ecosystem) for building real products: robotics (ROS 2), vision, gateways, kiosks, and on-device AI.
Examples of powerful Linux software Axon-Mini can run
Developer & productivity
  • Visual Studio Code (remote dev, Python/C/C++ workflows)
  • Git, CMake, GCC/Clang, Python toolchains
  • Docker / Podman for containerized deployment
  • Node.js for dashboards and device UIs
Feature strip
  • VS Code
  • Docker
  • ROS 2
  • RViz2
  • OpenCV
  • GStreamer
  • FFmpeg
  • WireGuard
  • MQTT
  • Nginx
Feature strip
  • VS Code
  • Docker
  • ROS 2
  • RViz2
  • OpenCV
  • GStreamer
  • FFmpeg
  • WireGuard
  • MQTT
  • Nginx
Vision, media & streaming
  • GStreamer (camera pipelines, streaming)
  • OpenCV (vision + preprocessing)
  • FFmpeg (encode/decode, record, transcode)
  • RTSP/streaming servers (for camera deployments)
Networking, security & device management
  • OpenSSH (remote access)
  • WireGuard / OpenVPN (secure remote networking)
  • Nginx (local web UI / reverse proxy)
  • Mosquitto (MQTT) (IoT messaging)
  • Prometheus Node Exporter + Grafana (monitoring dashboards)
Axon-Mini isn’t just an SBC, it’s a full Linux computer in a tiny, powerful form factor, capable of running 70,000+ Linux software packages (Debian ecosystem) for building real products: robotics (ROS 2), vision, gateways, kiosks, and on-device AI.
Robotics (ROS 2)
  • ROS 2 (Humble/Iron/Jazzy workflows)
  • RViz2 (visualization)
  • Gazebo / Ignition (simulation, when used)
  • MoveIt 2 (robot arm planning)
  • Nav2 (navigation stack)
Robotics (ROS 2)
Edge AI workflows
  • ONNX Runtime (model inference)
  • TensorFlow Lite (edge inference)
  • PyTorch (where practical for your workload)
  • JupyterLab (rapid prototyping)
Edge AI workflows
Technical Specs
CPU
Qualcomm® Universal Bandwidth Compression
(UBWC) with camera, display, GPU, video, and
compute DSP
Kryo Gold plus: high-performance core up to 2.7 GHz
Kryo Gold: three high-performance cores at 2.4 GHz
Kryo Silver: four low-power cores at 1.9 GHz
GPU
Qualcomm® Adreno™ 643L, support OpenGL®
ES 3.2, DirectX® FL 12, OpenCL™ 2.0, Vulkan®
VPU
Adreno VPU 633 – fifth-generation UHD video processing unit
Video decode up to 4K60 for H.264/H.265/VP9
Video encode: Up to 4K30 for H.264/H.265
Video concurrency: 1080p60 decode and 1080p60 encode/ 4K30 decode + 1080p30 encode
HDR playback: Support for HDR10 and HDR10+
ISP
Triple 14-bit image signal processing (ISP) + two
lite ISP 22 + 22 + 22 MP, 64 MP/30 fps
DSP/NPU
Hexagon DSP and 12 TOPS NPU
Storage
Onboard 32GB High - Speed eMMC 5.1
Onboard expandable UFS 3.1
Support PCle 3.0x2 NVMe Storage via B2B Connector
Memory
8GB/16GB LPDDR5 3200 MHz
WIRELESS
Integrated WiFi-BT Combo Module (AMPAKAP6276S)
WiFi 2.4 GHz/5GHz/6GHz 2T2R
Bluetooth® 5.3
Onboard Virtual Antenna and U.FL
Connector with RF Switch
